I'm happy with my 4080 without any overclocking. But I figured why not try to overclock since the thermals are so low. And I paid a lot. I wanted to get the most
of of my 4080's high cost. lol And it seemed like something fun to learn. I don't overclock anything else in my build. Of course I use XMP on my Ram etc. But my 12700K is factory default.
See my profile signature for full PC Specs if needed. I have 1000W PSU not listed in Signature. And my monitor is 1080P 240Hz.
Relevant Info
In this review https://www.kitguru.net/components/...ass/gigabyte-rtx-4080-gaming-oc-review/all/1/
They overclocked the same exact GPU "4080 Gigabyte Gaming OC" that I have to +90Mhz for the Core. And +1780Mhz for the memory.
I used the same program they used. MSI Afterburner. I slowly increased the Overclock working towards the +90mhz and +1780mhz
But I had artifacting in Final Fantasy 15 at +80Mhz +1680mhz. So I had to lower things.
I ran a series of tests and game play tests. I have no artifacting what so ever at Core +75mhz and Memory +1400Mhz. Gamed for hours no visible issues.
Thermals are also fine. GPU hot spot reaches 79C with 3DMark Stress Test 20 Loops. The GPU itself reached 68C MAX. This is with like 20 Loops
of 3DMark or while gaming. With Furmark 30 minute stress test I got up to 82C Hotspot. And I even checked processor thermals too. Generally my
CPU maxes out at 72C while gaming or using 3DMark.
Average and Max FPS increase while in Overclock. And Cyberpunk gains about 3-4 FPS. lol Meaning I don't really think I need to overclock. Maybe for
games where my FPS dips below 60 ir could come handy. But maybe for blender etc it could be useful I don't know.
Am I overclocking wrong? Should I get more then 3-4 FPS in most games? 3DMark Benchmark scores do increase when overclocking. And I don't know
if this is important but 3DMark Stress Test while overclocked passed with 99.4% FPS stability. This was a 20 loop test. It needs 97% to pass.
I feel like 99% or higher is very good. But I assume 3DMark is a synthetic test. And can't be used to guarantee real world results while gaming.
1. I don't know what is more important to overclock on a 1080P setup? Core or Memory or if you need to find a perfect balance etc? Remember
I know almost nothing at all about this. I assume overclocking both can be benifical to gaming, and applications like Stable Diffiusion or Blender.
2. Is it normal to lose Minimum Frames as well as 1% lows while overclocking? GTV 5 and Cyberpunks built in Benchmarks report this to me.
But I've also monitored FPS while playing too. And my FPS monitor reported a slightly lower minimum and low 1% avg.
Examples
Cyberpunk Ultra Settings, Ray Tracing on , DSLL completely off. (Ran the Benchmark a few times)
Non-OC
Average FPS 90
MAX FPS 118
Min FPS 64
Overclocked
Non-OC
Average FPS 94
MAX FPS 119
Min FPS 48-58 (While the other FPS results stayed fairly consistent. Min FPS fluctuated between tests and was decently lower while overclocking.)
GTV 5 (These kind of seem all over the place to me. Almost like the Benchmark it not perfect. or my game settings need adjusting too.)
Non-OC
Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 16.640070, 155.332565, 123.507942
Pass 1, 35.758343, 161.092850, 116.191498
Pass 2, 30.814648, 203.848663, 141.378784
Pass 3, 34.060989, 256.456299, 168.921249
Pass 4, 6.002087, 238.663467, 125.710945
Overclocked
Pass 0, 17.002609, 150.305862, 124.076401
Pass 1, 39.458160, 158.591705, 116.472008
Pass 2, 31.899452, 211.291412, 141.099152
Pass 3, 5.241041, 278.877777, 168.408203
Pass 4, 6.465227, 250.676819, 127.738876
3D Mark Time Spy Extreme Score (Ran the Test Twice for both non-OC and Overclock)
Non-OC
Score 12405 to 12416
Overclocking 4080 to +75 +1400
Score 12870to 12892
Finally while in game. GTV, Cyberpunk and few other games.
I noticed Average FPS increasing by about 3+ but like I've said minimum fps drops. Usually by 1-2 FPS while in game. Maybe
more but I'm having trouble actually testing it. You may want to ask me if this makes the game noticeably stutter? No not really.
But at the same time I don't notice the smoothness of adding 3-4 FPS either. lol So for the games I've tested and I've tested 4+ games.
Overclocking does change my FPS counter. But I don't notice actual game play differences. And unless I'm playing a game that dips below
60 FPS I probably should not expect it too. But I feel like Overclocking is not suppose to lower minimum frames?
3. I use Hwinfo64. So I've monitored Wattage, temps etc. During these Benchmarks and Stress tests.
I'm going to provide links to two images. One is Hwinfo64 Time Spy Extreme 20 Loops. The other is Furmark
GPU Stress Test. If you see anything that I should be concerned about please let me know? Like
with the Wattage/Power draw etc.
seem worth it. I may need to adjust the overclocks values and figure out if adjusting it may
improve results? Maybe you know of a better Benchmark or Test to run? This is mostly for fun.
From your greater experience with overclocking. Is my GPU an example of don't bother?
or is there maybe still reason to continue? Should I be able to get better results?
Have you seen these issues before?
Thank you I am brand new to overclocking. Hints are welcomed.
And yes I know I can turn OC on and off at will. So I plan to keep it off for most games and applications.
I'm already running most games at like 90-130+ FPS on Ultra etc. But maybe Overclocking can help in some applications or uses.
Relevant Info
Examples
Non-OC
Average FPS 90
MAX FPS 118
Min FPS 64
Overclocked
Non-OC
Average FPS 94
MAX FPS 119
Non-OC
Overclocked
Non-OC
Score 12870to 12892
- https://postimg.cc/682YLGvs 3DMark 20 Loop
- https://postlmg.cc/p5rDWgQN Furmark Stress Test
