They've done it before with Maxwell following Kepler on the same node. 980Ti was slightly larger than 780Ti. Much faster while using slightly less power.Nvidia would need to pull a rabbit out of its hat to get significant performance improvements while sticking with a revised version of the existing node. As noted above, if consumer Blackwell GPUs still use 4NP, the only way to get more performance is with bigger chips and more power.
Svelte means slender. It's used to describe people, not things, and it implies a certain elegance.
Gotta agree. I hate to see the same 12VHPWR cable used again in these cards. I don't trust these cables despite the new revision released recently.I hope they got rid of this piece of crap power connector that is a big engineering failure.
What's the point of miniaturizing a connector when the GPUs are so huge anyway... ?
That was a very different era of GPUs, though. I'm not saying it can't be done at all, but Kepler was clearly a non-optimal GPU configuration and Maxwell improved things a lot (and dumped some stuff that was eating power as well, IIRC). Ada Lovelace is, by all appearances, quite optimized. To get more performance without increasing power use (or even reducing it) would imply that Ada left a lot of room on the table for future improvements. I simply don't believe that's been true of the past several generations of GPUs from Nvidia.They've done it before with Maxwell following Kepler on the same node. 980Ti was slightly larger than 780Ti. Much faster while using slightly less power.
