Running 2 different GPU's in my system
iizdat1n00b
37
First thing, I don't want to use these in SLI
My problem is I have a GeForce 770 for gaming and whatnot, and I just put an old Quadro FX 3700 in the PC. I would like to use the Quadro card for rendering and dedicated PhysX. I plugged in the card and the fan is making a really loud sound. So what I would like to do is turn down the RPM, but I can't get the card recognized by the system.
My displays are plugged into the 770.
I got it installed correctly with the power plug. I know it has enough power because if I remove the plug from it, it makes a very loud beeping sound, which I would assume it makes when it does not have enough power.
