B bfieldpinch Apr 11, 2018 7 0 10 May 14, 2018 #1 Will running an Alienware 15 R3 24/7 as a desktop replacement shorten the life? Assume the laptop is left off to the side with the lid closed or partially closed.
Solution The Paladin May 14, 2018 get a dock for it if is available, it will configure it for most air flow underneath it, if not then get a nice usb fan system to sit your laptop on. something looks like this https://www.monoprice.com/product?p_id=8420&gclid=Cj0KCQjw5-TXBRCHARIsANLixNwGk4OvnDP-lIwAgG0J-lW1JFO84MLDbZmcU_OeuVIABVoi2RRQqX0aAs5DEALw_wcB
CountMike Titan Oct 31, 2015 35,668 3,834 147,990 May 14, 2018 #2 As long as it's kept cool no harm should come to it. Upvote 0 Downvote
The Paladin Titan Ambassador Oct 5, 2016 9,659 63 75,340 May 14, 2018 Solution #3 get a dock for it if is available, it will configure it for most air flow underneath it, if not then get a nice usb fan system to sit your laptop on. something looks like this https://www.monoprice.com/product?p_id=8420&gclid=Cj0KCQjw5-TXBRCHARIsANLixNwGk4OvnDP-lIwAgG0J-lW1JFO84MLDbZmcU_OeuVIABVoi2RRQqX0aAs5DEALw_wcB Upvote 0 Downvote Solution
