running an i3 6100 on a msiz170a: is it better to buy 8gb 2133mhz hyperxfury ddr4 CL14 or 8gb 2400mhz CL15?
allmando
Commendable
Nov 18, 2016
11
firstly what does CL14 and Cl15 even mean?, secondly, will the 2133mhz hyperxfury CL14 (http://www.ebuyer.com/704615-hyperx-fury-black-8gb-4gb-x2-ddr4-2133mhz-cl-14-memory-hx421c14fbk2-8) run better on an i3 6100 than a 2400mhz CL15 (http://www.ebuyer.com/720289-hyperx-8gb-2x4gb-2400mhz-ddr4-non-ecc-cl15-1-2v-memory-hx424c15fbk2-8).
btw, price is not an issue; they both cost the same amount - around £50 - i just care about which one will give the best performance with my i3 :)
any help would be much appreciated!
It's not DDR4 2400 CL14 it's DDR4 2400 CL15, - my question was if the change from "Cl14 to Cl15" would or wouldn't be worth it - thanks for the quick reply though :)
ok, I think I'll go with what you recommend, and the 2400mhz CL15, thanks very much and have a fantastic day :)
