[SOLVED] Running out of ideas for what I can do to my computer next. Need recommendations.
I just recently installed my first NVMe drive (Actually its the first Solid State Drive I have ever owned). Next I plan to put an inexpensive heatsink on the NVMe drive mainly for aesthetics but I figure it will help the temps some under sustained loads.
My next larger upgrade is to finally install my brand new Seasonic S12ii 520W Bronze PSU I have ready to install along with purchasing and installing a Noctua NH-C14S CPU Cooler. I think doing both at the same time makes the most sense since I have to disconnect the power supply anyways to perform the CPU Cooler install. I would have to remove the motherboard to perform this install correct? I chose the NH-C14S because it will fit in my case and blow air down towards the VRM's as well. If you have a better suggestion that will fit the Corsair 100r I'd be interested in hearing your opinions.
After that I'm not sure what else I can do to this PC, I'm not interested in LED's/RGB. I could add e few more Noctua NF-S12B redux-1200 PWM fans I suppose. I already have one such fan in the system pulling air out of the top of the case. The rear case fan is a 120mm stock fan that came with the case. It seems to be holding up well 1.5 years later and I never hear it.
TL/DR - What else should I add to my computer besides an NVMe heat sink, CPU Cooler and Noctua Redux fans.
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 3.2 GHz 6-Core Processor (Purchased For $169.99)
Motherboard: ASRock AB350 Pro4 ATX AM4 Motherboard (Purchased For $120.00)
Memory: Corsair Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory (Purchased For $120.00)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory (Purchased For $69.99)
Storage: MyDigitalSSD BPX Pro 240 GB M.2-2280 NVME Solid State Drive (Purchased For $44.99)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive (Purchased For $39.99)
Video Card: EVGA GeForce GTX 950 2 GB FTW ACX 2.0 Video Card (Purchased For $179.99)
Case: Corsair 100R ATX Mid Tower Case (Purchased For $59.99)
Power Supply: Thermaltake TR2 600 W 80+ Bronze Certified ATX Power Supply (Purchased For $60.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer (Purchased For $18.89)
Operating System: Microsoft Windows 10 Home OEM 64-bit (Purchased For $109.99)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter (Purchased For $35.11)
Case Fan: Noctua NF-S12B redux-1200 PWM 59.1 CFM 120 mm Fan (Purchased For $14.99)
Monitor: AOC e2752Vh 27.0" 1920x1080 60 Hz Monitor (Purchased For $243.79)
Mouse: Logitech MX Anywhere 2 Wireless Laser Mouse (Purchased For $53.38)
Headphones: SteelSeries Siberia V2 Headset (Purchased For $60.85)
Speakers: Logitech Z623 200 W 2.1 Channel Speakers (Purchased For $129.99)
Custom: Chicony KB-5911 rebranded as Micro Inovations - Model # KB-5911 (Black) (Purchased For $4.24)
Total: $1536.17
Generated by PCPartPicker 2019-10-15 10:07 EDT-0400
I would love to have one Vega 56, my 950 FTW can't come close to it in performance. I don't have a free slot for a 2nd one however.
So in summary - you all think I should upgrade the video card before doing anything else to the computer?
Yes seems like the best thing to do
