Hi everyone. I kinda have a problem.
Recently i purchased the almost last component for my pc which is the processor and the remaining one is the graphics card.
When i bought the cpu i thought i can run my pc without a graphics card. But apparently i cant, or i've done things wrong.
So, my motherboard [ msi h110m pro-d ] has a dvi-d port. I connected an dvi to vga adaptor in it to make possible connection to my monitor. But when i power it on, nothing shows up on the monitor. It says 'no signal'.
Oh and one more thing. When i press the power on button some of the "EZ system debug leds" are blinking.
The +CPU for like 1 second and then it turns off and the +DRAM goes on for 4-5 seconds.
I've been to a service and they tested every single component. Everything is working properly.
So in the end i have 2 questions.
Can i run my pc without a graphics card or do i need to buy on to make it post?
Is it going to work if i will use a friend's video card to install windows & drivers and then give it back to him?
PC components
Motherboard: MSI h110m pro-d
CPU: i5 7500 3.4ghz
RAM: HyperX Fury 8gb 2133mhz
Power suply: Sirtec - High Power EP-500BR II, 80+ Bronze, 500W
Hdd: wd blue 1tb 7200rpm
PC components
CPU: i5 7500 3.4ghz
