RX 460 keep crashing and recivering
lukastevanovic38
12
Driver is crashing only while im gaming. I took the computer to service and my friend, where every game was tested and worked without crash. When i took computer , driver keep crashing. I've tried DDU, underclock gpu, bought hdd, new psu, updated bios and it didnt work.
Spec:
OS: Win 10 Pro 64bit
MB : AsRock N68-GS4 FX
CPU : AMD FX 4320
HDD : Toshiba 500gb
RAM : 8gb 1600mhz
GPU : Gigabyte AMD RX 460 2gb ddr5 oc windforce
PSU : LC POWER LC500h-12 500w
Thanks in advance :)
Radeon Product Compatibility
Radeon Software Crimson ReLive Edition 17.4.3 is compatible with the following AMD Radeon products.:
Radeon™ RX 400 Series Graphics
So, 17.4.3 supports RX400 series.
You also can try 17.4.4. Maybe 17.7.1 will work too for you, idk. I just use 17.4.3 because now it works for me and i don't want to experiment further (also it was last WHQL driver version available at the moment of my testing, anyway, anything beyond 17.7.2 makes Overwatch unplayable so i don't even use them until AMD fix it, also i believe 17.7.2+ have issues with Afterburner).
I've tried ccleaner and it didnt work , when i downloaded malwarebyter there were 174 threats and i deleted them , but driver is still crashing.. i checked the task manager i there isnt too much stuff. Gpu is not overheating temp is fine , cpu temp is fine .. .
Yes, i have LC POWER LC500h-12, but i dont know what is +12 rails, but it may be psu , when i replace the old gpu (gt 720) witch is requare 19 watts, there is not crash. And im not getting message when driver is crashed, i can only see message in event viewer Display driver amdkmdap stopped responding and has successfully recovered. Sry for bad english.
http://prntscr.com/gntlgt this? Is this psu enough for my components http://www.emmi.rs/napajanja-i-dodatni-ventilatori-napajanje-550w-energon-eps-550w.11.html?productId=63740?
Gigabyte RX460 2gb ddr5 windforce OC
I have a 4Gb version of Gigabyte RX460 in my girlfriends PC. MB is horribly dated M5A78L-M LX3, FX-8320e CPU, some old 500w PSU (powerman or something like that). Had random black screens and driver crashes as well. Looks like i've got some workaround, at least for this PC:
- I uninstalled drivers using DDU
- Installed 17.4.3 drivers without AMD Settings/Wattman
- Downclocked GPU to 1000mhz using MSI afterburner
Not a single driver crash for a month now and my gf can finally play competitive overwatch.
It may work with other driver version as well. Maybe even with AMD Settings installed but Wattman deactivated. Downclocking card to 900 mhz in Wattman (and even playing with powerlimit) still crashed drivers while 1ghz via afterburner is stable.
Probably your problem is bad compatibility of PCIe3.0 8x RX 460 with your PCIe2.0 old board (it happened to many people, power delivery issues), also looks like Wattman brings some issues too. Give afterburner a try.
How to download driver without amd settings??
Just download regular package and choose "custom install" instead of "express install" during installation process. Select only driver components (display and hdmi audio).
Ok, ill tell u if it works
Wait u sure i have to download 17.4.3? Cuz its only support rx 580 and rx 570
Ok ok, ty ill try that
Driver is still crashing... But ty anyway.
What do u think? Should i buy new psu?
