Solution maxalge Aug 28, 2016 floww123 : Will a rx480 fit on a nox pax 3.0? depends on the rx 480 version you want that case can fit max 370mm length gpu's
maxalge Champion Ambassador May 31, 2012 13,371 4 56,960 Aug 28, 2016 Solution #2 floww123 : Will a rx480 fit on a nox pax 3.0? depends on the rx 480 version you want that case can fit max 370mm length gpu's Upvote 1 Downvote Solution
