[SOLVED] Rx 570 4g monitor no signal
fragileiiv
30
Im having some issues with my gpu
I put a rx 570 red dragon 4gb on my byild however it seems that my monitor is not connecting to the gpu
No signal !!!!
But if i connect the monitor to my apu
Ryzen 5 2400g its working
Heres my build ryzen 5 2400g
Gigabyte b450 ds3h
Rz 570 power color 4gb
4x2 crucial 2666 oc to 2833 mhz ram
Rave 500w 80 bronze
That PSU is GARBAGE. You should upgrade to a more reliable PSU of a reputable brand even if it's not the root of your problem.
Try another monitor or TV if possible to see if the problem still exists. Change the BIOS setting to use only PCIe for display.
Make and model of PSU?
Latest BIOS/windows updates/chipset drivers?
Rave 500w 80 bronze
Latest
So i was able to use the gpu it just that there seems to be some delay for my monitor to detect my gpu
Should i change the initial display output? To pci e slot?
And also the monitor show no signal ehen im going to bios
Thanks , ill go and try to doing
Yes im aleady planning to upgrade my psu yo evga
