P potkol1997 Commendable Apr 9, 2017 13 0 1,510 Apr 20, 2019 #1 I'd like to ask if my mobo acer tc 705 compatible with rx 570
Solution Dark Lord of Tech Apr 20, 2019 Yes it's compatible as long as it will fit in the case you have a decent PSU with enough power.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Apr 20, 2019 Solution #2 Yes it's compatible as long as it will fit in the case you have a decent PSU with enough power. Reactions: potkol1997 Upvote 1 Downvote Solution
