Question RX 6900 XT underperforming, fps drops, spikes and lags
Feb 7, 2022
Hi guys
I need some help, recently I got my first amd card -rx 6900 xt sapphire nitro+ se. I swapped from rtx2070s and to my surprise, Im having trouble after trouble
The biggest one is that Im having contstant drops and frame spikes every minute, as you can see on graph
View: https://imgur.com/a/48fsB3R
I tried, swapping to pcie 4.0 on mobo
turning on and off free sync,
capping fps
fresh install of everything
all extra features of adrenalin are turned off
sam on
when I turned off pbo I think spike were a little bit less often
Rest of build:
ryzen 9 5950x,windows on nvme, x570-f asus, psu corsair hx1000, drams from corsair, 16gb 3000@3200
I dont have any temp problems, problem is occuring in older titles too
I really need some help, problem is connected to GPU or mobo, swapped them at once
If you reinstalled your OS, did you recreate your bootable USB installer to rule out a corrupt OS installer? Speaking of which, what OS are you on? BIOS version for your motherboard? You've listed the specs to your build, partially. Please parse a link to ram kit used. Make and model of the SSD and which slot it's occupying?
I made a fresh windows install, installed all from scratch, from drivers to soft
Win 11, last version
latest bios
Corsair Vengeance LPX, DDR4, 16 GB, 3000MHz, CL15 (CMK16GX4M2B3000C15R)2x8gb -working in dual channel
ssd nvme , some pny 1tb without cache
2nd ssd mx500 I think
nvme is connected in slot no:1
Here's my gpu settings
