Question Rx 7800 XT Crashes and Low FPS...
Rajveer7827
30
Update: I want to tell you guys that the thing was 8 Pin PSU Power Connector connected to GPU was only one Cable with Splitter so i connected two Separate 8 Pin Connectors to the GPU, another thing was the Hard Drive Connector was touching and stopping one GPU Fan from spinning and Last and most important culprit was all three games i tested are out of date version in my PC, so i tested some more games i downloaded and installed earlier and bang...No crashes in other games. I'm hitting 120 FPS in Starfield with Max Settings 1440p and 80 FPS with Max Ray Traced Settings. In Spider-Man Remastered I'm getting 130 FPS with 1440 Max Settings and 90 FPS with Max Ray Tracing. In Spider-Man Miles Morales I'm getting 110-130 FPS with Max 1440p Settings and 60-90 FPS with Max Ray Tracing. After updating Cities Skylines II I'm getting 60 FPS with 1440p Max Settings, before updating i was getting only 30 FPS lol (This game is poorly optimized and more dependent on CPU rather than GPU). I will update the RDR2 game and tell you guys if FPS improves. Thank you for replying and being helpful
I'm having issues like Random Crashes to Desktop and Even System Reboot while Gaming, Low FPS in Modern Games (RDR2 55 FPS at 1440p Ultra and 90 FPS at 1440p Medium) (60 FPS at Microsoft Flight Simulator at 1440p Ultra)
But my build is brand new, everything is new:
ASRock Challenger 7800 XT,
Ryzen 5 7600X,
Kingston Fury 32GB (16GB x 2) DDR5,
Kingston NV2 NVMe Gen4 1TB,
Cooler Master G800 Gold 800 Watts PSU,
Cooler Master Hyper 620S CPU Cooler,
MSI Pro B650M-P MOBO,
Cooler Master MasterBox K501L Case,
Fresh Windows 10 Pro Install
My GPU Temperature was 80°C in Red Dead Redemption 2 Ultra Settings and CPU Temperature was 65°C
I was using AMD Adrenaline Software before. I have tried Clean Uninstalling the GPU Drivers with DDU and Reinstalling the Base Drivers without Adrenaline Software but the problem is still there. What's going on in my case? Do i need to get my GPU replaced from ASRock Service Center?
