[SOLVED] rx580 Basic frequency 1200MHz !!!!!
Looks like it may have been BIOS modded, possibly for mining. The GPU clock would normally be higher and the memory clock would normally be 2000. You can change the values using AMD Wattman if you'd like, that'd be the easiest/safest way to do things. You could also try flashing the default BIOS. I'm not certain exactly which model you have, but here's a list of the BIOSs that techpowerup has for XFX RX 580s. https://www.techpowerup.com/vgabios...el=RX+580&interface=&memType=&memSize=&since=
Reactions: kong6j
