Question Ryzen 2700X max memory
finwizz
133
4
4,585
Notice that Ryzen 2700X spec states maximum memory size and speed as DDR4 2933Mhz. On the net have read about people using DDR4 3200Mhz memory. Will there be an issue with the higher memory?
Then, in that case, go for 2x16, I believe ASUS uses daisy chain for their DIMM slots. And yes 3200 CL16 should work, if you plan on overclocking it past that, go for a 3200 CL14 kit, because they are b-die (the best type of die for memory) if you can afford it. Other than that 3200 CL16 should most likely work on the zen+ architecture.
Reactions: finwizz
