Ryzen 3 1200 + Asus Geforce GTX 1050 ti Low GPU usage (20% to 50%) cause massive FPS drop
ketuman
23
System Specification :
CPU : Ryzen 3 1200
GPU : Asus Geforce GTX 1050 ti 4 GB
GPU Drivers : 388.41
Motherboard : Gigabyte AB350 Gaming 3
RAM : HyperX Fury 8 GB 2400 MT/s
Power Supply : Zebronics 600W
HDD : 1 TB WD Blue
Monitor : Resolution 1366x768
Windows 10 64bit
I have noticed massive FPS drops in Battlefield 1 so i have turned on necessary stats with MSI Afterburner to diagnose performance of GPU and CPU performance,
It was 20% to 50% GPU usage with 100% CPU usage, clocks and Memory usage was also good. with All Ultra,low and medium settings. Also V-sync off. FPS limited was good. I was getting only 20 to 55 fps.
So i checked out other games as well CSGO and Battlefield 4 same thing happened with this games also. GPU usage is not going above 55%.
I did stress test where GPU usage was almost 100%.
I have seen youtube videos where people are playing battlefield 1 with 100% CPU and GPU usage with same specifications as mine Ryzen 3 1200 and GTX 1050 ti.
So something is wrong.
Tried this solutions :
1) Re-plugged GPU
2) Nvidia Control panel power option set to maximum performance
3) Reinstalled games
4) Set memory restriction to ON/OFF
5) Turned ON/OFF DX12
6) Rolled back GPU Driver
7) BIOS is upto date
8) Vsync ON/OFF
But none of the above worked.
Please help me to solved this problem.
Thanks and Advance. :)
Thank you for your reply. :)
I will try that and update it that it worked or not. :)
I will do above things. I tried to defrag disk but its already 0% fragmented.
Its hard to get 1920x1080 monitor ... and problem occurs in multiplayer and i didnt try in single player.
No i didnt alter page file or any windows settings .. i dont what is page file actually.. 😀
I just checked page file size which is showing 3840 MB. Is it ok? I have 8 GB RAM. What should be optimal?
Finally everything is fine after installing new fresh windows 10. Still dont know what was the problem, either it was power supply or Bad windows 10 or virus/Malware. But changing power supply is a good recommendation to be in future so i did so.
Thanks you everyone for help me.
i didnt understand this. There is no 6 pin connector port in 1050ti. or you are talking about motherboard 6 pin connector?
