Ryzen 3 1200 overclock to 3.9 settings help
AzureYukiPoo
Commendable
Jan 22, 2017
19
am unable to overclock my ryzen 3 1200 to 3.9
am currently running it at 3.8 with 1.300 volts then my ram is overclocked at 2667 at 1.35
or did I just get unlucky with the silicon lottery?
also am using the stock cooler with bios updated to 3.30
cpu: ryzen 3 1200
mb: asrock ab350m hdv
ram: 2x4gb corsair vegance lpx 2400
http://www.guru3d.com/articles-pages/amd-ryzen-3-1200-and-1300x-review,27.html
Agreed, there is the silicon lottery so there's no guarantees.
The above link showed 4.0GHz but that's with 1.4V applied which obviously drives up the temperature. They used a stock cooler so it's at least possible.
I'm simply not experienced with Ryzen though note in the above link they suggest an OFFSET be applied instead of a fixed voltage.
It is about 2.5% gain per 100MHz.
@ThatVietGuy 450w psu. When i try 3.9 or 4 the pc just doesnt boot up. I have to reset cmos. I might have lost the lottery. Temp wise been able to use it properly and play games. Temp reaching 60-65.
@photonboy Hmm offset? I could try that and maybe a ram upgrade in the future if it is indeed due to my ram unable to reach higher speeds that might hinder my oc to 3.9-4
