Ryzen 3 2200G and AB350 PRO4
Aug 5, 2018
12
I want to make this short, these are my specs:
Ryzen 3 2200G
AB350 PRO4
GTX 1060
Corsair Vengeance LPX
PC turns on but monitor doesnt show diplay, please help fast!
Azzyasi
86
4
18,645
4
you need a first gen ryzen to boot, then update the bios. You have 2nd gen ryzen and you must update the bios first to support 2nd gen, and this is not easy if you can't power on. So get hold for a few minutes of a ryzen 1st gen in order to update the bios.
Azzyasi
86
4
18,645
4
Of course.
As I understand, it's a new build, and it never booted in this configuration, i'm 99% sure the bios is not updated for the 2nd gen of ryzen. So it will not start (it will spin up a bit, maybe even some flashes from the gpu, and then halts at CPU)
You need a 1st gen am4 cpu (ryzen 1xxx or other from same gen) to update the bios to support the 2nd gen of ryzen.
If the motherboard is new you can contact the vendor to help you with the update of the bios. Send it to them.
Or do it yourself if you can get a hold of 1st gen cpu from a friend or something.
300 series of chipset is for 1st gen, 400 series chipset is for 2nd gen right from the box.
300 series chipset has updates to support the 2nd gen but most likely the mb sits in that box befor the update was available so you need to the update the bios by any means.
Aug 5, 2018
12
I do believe this is the answer, thanks for the help everyone who contributed!
Similar threads
