Hi everyone,
I recently upgraded my rig moving from an i5-4690k to a Ryzen 3600.
I only changed the CPU, the motherboard and the RAM and kept the rest from my previous build (GPU, case, PSU and cooler).
I did some quick tests to check temps with the new Ryzen processor and there are quite high to me (especially if I compare with my old i5).
On idle, it usually varies between 40 and 50°C.
In game, it is usally around 75°C except with Ahtem where it reaches sometimes 82°C.
I also tested the CPU with OCCT and reaches 82°C at max after 30 minutes.
I'm using my Dark Rock 3 that served me well with my i5. But here it seems not enough.
So are my temps normal or is it too high?
Thank you in advance.
