Hi all,
My setup is as follows:
Ryzen 3600
MSI B450m Mortar MAX
2x8 GB 3600Mhz Corsair RGB Pro
RX 580
Corsair H100i
Cooler Master MWE Gold 650W
Recently I've purchased an RX 5700 XT. After installing its drivers I decided to run some benchmarks, and it turned out that my CPU suddenly underperforms heavily. Cinebench R15 score dropped by 40%, and userbenchmark says the CPU is in the 1st percentile of lows (was 70th percentile previously). In the mean time i've also relocated my radiator from the top to the front of the case, but while doing so the cooling block stayed attached.
To do some testing, I've switched my GPU back to an RX 580 with which the previous benchmarks were ran. However, problems still persist. After that I tried reseating the CPU, but this also didn't improve anything. I've never overclocked my CPU. Any ideas what might be causing this?
Temperatures have gone from 75C while benchmarking to 50C with the radiator change, don't know if that has anything to do with it..
Thanks a lot in advance!
Ryzen 3600
RX 580
Corsair H100i
