Discussion Ryzen 3700x Max Single Core Clock Speed ?
DMAN999
Dignified
Ambassador
What is the Maximum single core clock speed your Ryzen 7 3700x hits ?
I was just wondering what everyone is getting for a max clock speed because of all the recent press about these chips not hitting the Max clock speeds (4.4 GHz ).
Mine hit 4375 MHz (4.375 GHz) on one core while running Cinebench R15:
View: https://imgur.com/lsPjZLa
I am personally fine with the fact that mine doesn't quite reach 4.4 GHz, 4.375 GHz is close enough for me.
My full specifications are listed in my signature.
Can anyone help me overclock my 3700x all core I want to try to get 4.4 on all core with decent voltage. I have no clue what i'm doing but I enabled PBO and set voltage to 1000 watts I understood that it didnt matter since iti'll never use it either way so I did it. I heard it from buildzoid i think is the guys name anyways with the PBO enabled in CB20 single core it runs at about 4425 about 80% of the time and it sometimes hits 4450 I have no clue what im doing testing wise either lol. Please help have a good day stay safe y'all.
If you do not have a clue what you are doing then reset the cpu settings back to normal and get advice from these forums before you set voltage higher because things like this you can break it!
Why not, instead of dredging up an old thread that only peripherally applies, open your own thread in the overclocking forum?
Reactions: NightHawkRMX
