I disabled SMT and changed graphics mode to hybrid on my 2400g on a ROG Strix x370-f and my system will no longer POST. Everything was running fine and I only changed this setting because it was mentioned to have better performance in certain games that don't use multithreading. Resting the CMOS did not work. My error LED code is red which means CPU error. Tested pulling the memory out to see if I would get a memory LED code but I do not, the system powers on only briefly before turning off. I am at a loss of what to try next and don't know if I should be starting the RMA process with the mobo or the proc. Any suggestions are greatly appreciated.
System was running entirely fine until this.
Things I've tried... Reapplying thermal paste and reseating CPU, no go.
Reseating the CPU cable and MOBO cable, no go
Disconnecting all hard drives, optical drive, USB devices etc. no go
Tested powering on with no RAM installed, no go
I really thought reset the CMOS and good to go was all that was going to be needed, that didn't work as well.
ROG strix x370-f
Ryzen 5 2400g
8GB corsair ddr4 3000mhz
650w bronze rated EVGA power supply
ROG strix x370-f
Ryzen 5 2400g
