Hello, i know there's a lot of people who have been asking bout Ryzen 5 2400G temps. But i never found one with my case.
I am living in a tropical weather with ambient temp around 30C +/- 4C
When idle, my Ryzen temps stays around 35 to 37C, which is quite normal according to several thread i read. When i game (The Witcher 3, DOTA 2, etc) it jumps to around 65 - 70C (which again still quite normal according to what i read).
But the problem starts when i do rendering with blender.
with my case closed, the temps can reach to around 94C, and down to around 87C when i open the case side panel. While some other people only maxxed their ryzen temp around 75-80C even with sub optimal case airflow.
what do you think about this? is this just an outcome of poor airflow which i could solve with adding fans, or there is something else going on?
FYI, i am running my setup inside a slim midtower case with only 2x 80mm fan slot in the back, and some ventilation slot on the side panel. Do i need to buy new case?
Full setup are as follows:
- Ryzen 5 2400G + stock cooler
- Gigabyte GA-A320M-S2H
- 1TB Sata HDD
- 16GB 2400 Mhz RAM
- 450 watt 80+ bronze PSU
- 1TB Sata HDD
- 16GB 2400 Mhz RAM
