[SOLVED] Ryzen 5 3600 high idle temps
Hi,
I have Ryzen 5 3600 with stock cooler. I have high idle temps 50-60c and when i start running some softwares it goes to 75c. Why? This temp are not ok. Other have 40c idle temps.... What should i change?
My PC spec:
CPU & cooler: AMD Ryzen™ 5 3600 @Stockcooler
Motherboard: Gigabyte B450 AORUS M
RAM: 16GB (2x8) DDR4 Kingston HyperX Fury @3200MHz
Display: AOC 27V2Q
M.2 SSD: Adata XPG SX6000 Lite PCIe Gen3x4 M.2 3D NAND 256GB
Sound: Logitech Z200 2.0CaseRaidmax Blazar
PSU: LC Power LC6550 550W v2.3 80+ Bronze
Mice & keyboard: Logitech M171
Dont flap about temps, you are using the stock cooler... Ryzen 5 3600 stays at 4200mhz same as mine (something to do with system monitoring apps), it gets hot, ambient temp is stupid atm here in the uk. get some air flowing in the case, i have 6 fans in mine and im getting to about 72 with the crappy stock cooler, i also used the noctua compound what i got with my cooler (waiting for the am4 socket to be sent to me)
Just curious what ram speeds are you using, i use 3200mhz but is only running at 2400mhz, when i use the xmp the cpu dont boost.
T
Yes, will changing it lower boost, will it still boost when needed?
Window high performance setting keeps your cpu ready at its high state ready for anything. So there is no spin up time to wait for. Thus the idle temps will be higher because it is idling at it's high setting. It will still boost as needed, high performance changes other settings too like higher cooling state etc.
Reactions: Audio31
