Good morning/afternoon/night? boys
So I bought a R5 3600 and a separate cooler and I'm experiencing very high temperatures. I'm going straight to specs:
CPU: AMD Ryzen 5 3600
Cooler: Cooler Master Hyper 212 RGB Black Edition
Thermal paste: Corsair TM30
Case: Nox Hummer MC
Airflow: 1x front intake / 1x back exhaust <- both of these with stock fans / 1x top exhaust (Arctic P12)
MOBO: Gigabyte B450M DS3H
BIOS: F51 (latest, released about 2 weeks ago)
Here's an example: i just turned on the PC, and just after 3 minutes the CPU reached 70º. I'd like to remark that I configured a -0.048v offset:
As you can see on the task manager, the GPU is at 43º idle, so I think we can discard airflow issues.
I also installed the chipset drivers and applied Ryzen's high performance power plan (I messed up with the balanced plan and the voltage is extremely low, less than 1v.
Any thoughts on what's happening? I tried pretty much everything, I kinda think that it could be that my MOBO is crap. Everything is properly connected.
I also read somewhere that AMD has the sensor on the middle of the CPU, but I'm not sure if it's true
PD: hope this doesn't disturb any of you, I know this topic is very frequent
Case: Nox Hummer MC
