Question Ryzen 5 3600 is a bit hot and randomly restart
Jul 27, 2019
My system spec is:
Ryzen 5 3600 with stock cooler
RX 570 rog strix
16gb 3000 ram
Asrock B450m pro4 f
Problem:
After finally getting my Ryzen 5 3600 to work, I did a Blender Classroom benchmark. The temperature shot up to 95C in less than 5 mins! I took the cooler off, reapply the thermal paste and it still got to 95C albeit a little more slowly this time and suddenly the entire rig just shutdown and restart in the middle of the bench.
Even the 2200g I used to have never got this hot so quickly from a Blender benchmark, it usually takes about 30 mins to get to about 70C.
Temperature is observed using Core Temp
Also Cinebench r20 score seems to be lower than other people?? I got max 3488 on multi and 470 on single
What I have tried:
Checked airflow, just like before 2 in 1 out.
Latest BIOS and drivers, latest windows update.
All the screws on CPU cooler are pretty tight I actually let the store screw the CPU before I see the temp got too high and took it off to replace the paste myself actually.
Tested with both the stock paste and a Coolermaster paste.
Prime95 in blend mode, it jumped to 94 degrees in about 10 mins.
Aida64 with just CPU, temp reached 80 degrees and stable around 76.
I will provide more info if necessary
I wonder if this is because of defective CPU and I should return it or is it normal and should I get an aftermarket cooler? Please recommend one if I do have to.
Thank you very much.
