So i recently bought a ryzen 5 3600 (using the stock cooler) and am using it on a new asrock b450m pro4 motherboard which came ryzen 3000 ready out of the box. The performance is great but I have noticed that the cpu does not boost properly. I updated the bios to the latest version to try and remedy the problem but that didnt work either. Running cinebench r20 all cores boost to 3900 mhz (it hit 90c during this bench so im guessing thats why it didnt boost), and i get a multiscore of 3500 which I think is in the same ballpark as other 3600s. Userbenchmark tests also say its a good chip. Occasionally it will boost to 4.1 in the desktop but while gaming (csgo and pubg), only 1 core will boost to 4050 mhz and the rest are in the 3000-3800 range. Temps arent an issue when gaming as it only gets to 70-72c in pubg and csgo. Is something wrong with the chip or is this standard? FYI, I am running it in windows balanced mode with 85% minimum processing power which i think is recommended. I can provide any additional info if needed. thanks!
