Mean machine here are my systems specs.
GIGABYTE X570 I AORUS Pro Wi-Fi
Patriot Viper 4 Blackout Series DDR4 16GB (2 x 8GB) 4400MHz Kit
ID-COOLING ZOOMFLOW 240X Snow CPU Water Coole
With Ryzen master and by bios overclock I am trying to set my overclock to 4.7 GHz LOCKED but the clock speed will not stay locked. I’m trying to lock up the clock speed for gaming. Does anyone know how to lock the frequency?
I can't indicate better Bios settings without knowing the Motherboard.Is there som kind of efficiency setting I am missing. I have PBO turned off and AMD cool and quite
Where did you read that a 4.7ghz oc was a guarantee?With Ryzen master and by bios overclock I am trying to set my overclock to 4.7 GHz LOCKED but the clock speed will not stay locked. I’m trying to lock up the clock speed for gaming. Does anyone know how to lock the frequency?
The CPU down clocks with bios overclocking as well I have tried both as stated. It is very strange like the CPU is trying to be in cool and quite mode or like its just turbo clocking to 4.7ghz at times but while gaming it usually sits at 4ghzDon't use Ryzen Master
I am starting to think there is a option in the bios or something in windows preventing the OC to stay lockedThe CPU down clocks with bios overclocking as well I have tried both as stated. It is very strange like the CPU is trying to be in cool and quite mode or like its just turbo clocking to 4.7ghz at times but while gaming it usually sits at 4ghz
I am try to lock 4.7ghz to get maximum performance while gaming.
Thanks mean machine your right. Loose timing are the only way to run 4400. I found it’s best to lower the ram speed and tighten the timing up.It's a huge ask of the CPUs IMC to run at 4400Mhz when official support is up to 3200MHz. Better performance gains would be had with a lower frequency say at 3200MHz CL14 than 4400Mhz and no guarantee you will get the rated frequency even with very loose timings say at CL18-26-26-46
Your RAM kit are not listed on the MB QVL so they are not tested. You will have issues.
OC RAM are not simple Plug and Play and I doubt there would be an XMP or D.O.C.P profile for simple Overclocking at 4400MHz. The MB may be capable to support 4400Mhz but it will be the IMC that will determine the highest frequency you will get.
I have reviewed your Bios manual and unfortunately cannot determine it's full capability without seeing the sub menu structurers. Maybe you could link some Bios pics that will help show what's available.
HI , I have exactly the same issue , and already removed RYZEN MASTER but that didn't solve itThank you everybody for your input!!!
I really do appreciate the community of us nerds 👍🤓💪
Problem is FIXED I was overclocking in BIOs and monitoring in Ryzen master somwhere along the line Ryzen master was overwriting the bios OC. Deleted Ryzen master and did all OCing in bios. Went with 3800mhz ram due to overall performance was better the. Xmp 4400. Lots of memory timing tuning definitely helped. See results in the images
My system has a 3600XT on a B450 MSI mobo with latest Agesa 1.2.0.0 Bios
and the sysytem is 100% Stable via a BIOS OC at 4450Mhz all core on 1.25V CPU fixed (override mode)
BUT when I start any 3D game (like fortnite or COD) it's like the pc goes back to stock settings 3.6-4.35 Mhz very strange
I alredy turned off Game mode and Windows is set to High Performance powerplan.....
Thanks mate !!!Hey fellow over clocker. I had the same issue you are describing as well on one of my older builds. What I found is when you use a MSI Mobo and have there software installed it causes the games to lower the CPU frequency. I believe in the MSI dragon software it’s also called game mode. TURN THAT MODE OFF OR UNINSTALL MSI DRAGON SOFTWARE. Hope this helps you. Best of luck.
