Hey all
So I only have Steam open with 105 background processes running.
Utilisation 2-3%
Speed 4.5Ghz
Processes 220
Power mode: Best Performance
Preferred Plan: Balanced (Minimum Processor State 5%)
Why is it that I am reaching these high speeds for only having steam on? I noticed that If I changed my power plan to power saving then all the clocks would be in the 1700-1800 MHz during light loads.
EDIT: If I disable Core Performance Boost in the BIOS, would this help at all? Just to clarify I have done no overclocking whatsoever..
Can I get some advice here in regards to not having the speeds so high when my base speed is 3.40GHz
View: https://imgur.com/pNGLPVt
Utilisation 2-3%
Speed 4.5Ghz
Processes 220
