Question Ryzen 7 9800x3d very high temps in idle
Jan 17, 2025
4
Hello, today i got prebuilt pc and as soon as i started i noticed very high idle temps. Right now i have 66°C temps.
cpu cooler is noctua nh-d15 chromax.black
mobo ASROCK B650E Taichi Lite
case fractal Design Torrent Black RGB TG Light Tint
Please tell us a little about ventilation in the case; how many fans on input and how many on exhaust. Also what speed or percentage are these fans operating at. You could try this simple test: if you remove the side covers (and top cover if removable) do the temps drop significantly? That would indicate a ventilation problem.
case is fractal Design Torrent Black RGB TG Light Tint .
cpu fan 800rpm, case fans 770
i tried each side, both, no change.
The Noctua NH-D15 (@ op; DH15 doesn't exists) is rated for 250W, more than capable to cool the 9800X3D. That being said I would look into what rgd1101 posted, looks like a bad cooler install cause it should be around 45-50 idle with your setup.
Yes edited now, ty. What should i do? Just remove it and check thermal paste or what can be fault?
What is the AUXFANIN1 entry, is that all 5 case cooling fans? Normally these would be set to increase in speed as the CPU fans increase in speed but I don't see that in the chart you posted. You may need to set a new fan curve in your bios; refer to the bios manual FAN-Tastic section if necessary. As another test before taking the cooler apart or returning the system you could manually set all of your fans to run at 100 percent maximum and see what temp readings that produces. If temps don't come down at 100 percent then a cooler mounting problem is more likely.
Yes auxfanin1 are all other fans. I tried running fans on max and no change.
