Question Ryzen 8700G issue ?
Jun 10, 2024
Hello,
My new PC (built a few days ago) has a frustrating issue: the display randomly goes black or flickers. Interestingly, whenever this happens, the RGB lights on my RAM also turn off.
It's worth noting that I'm not using a dedicated graphics card (GPU) and am relying on the integrated graphics of the 8700G processor. However, when I connect an older GPU, everything seems to work perfectly.
I've already tried updating the BIOS to the latest version (2613) but the problem persists. Additionally, installing drivers through both Armory Crate and AMD's compatibility software hasn't yielded any improvement.
GPU: None
CPU: AMD Ryzen 7 8700G
Motherboard: Asus TUF GAMING A620M-PLUS
BIOS Version: 2613
RAM: Corsair Vengeance RGB DDR5 2X16GB 7200Mhz
PSU: SeaSonic G 450W Gold
Hello,
GPU: None
BIOS Version: 2613
Make sure your amd upgrading your amd chipset driver the one specified by the manufacturer
https://www.asus.com/uk/motherboard...esk_download?model2Name=TUF-GAMING-A620M-PLUS
Make sure AGESA is full updated
Please explain, how to do it? Thank you
Download directly from amds website
Remove any and all drivers related to Nvidia / AMD you currently have to avoid conflict including Asus crate it's a waste of space
Download the drivers here
https://www.amd.com/en/support/download/drivers.html
Before starting it up remove any and all AMD and Nvidia related drivers in your ass and removed programs
https://support.microsoft.com/en-gb... taskbar,select Uninstall or Uninstall/Change.
https://support.microsoft.com/en-gb/windows/uninstall-or-remove-apps-and-programs-in-windows-4b55f974-2cc6-2d2b-d092-5905080eaf98#:~:text=In search on the taskbar,select Uninstall or Uninstall/Change.
Thank you, yet nothing changed 🙁
Do you maybe have some more ideas?
EXP and EXPO are not mutually exclusive nor is XMP only for Intel.
Xmp was created by intel
Expo was made by amd
I'm well aware that it's not specific to intel
However duel channel 6000 is technically sweet spot for this chip if he wants best compatibility I would aim at expo.
That and I've also had issues with certain xmp profiles not playing ball. And considering these chips are memory sensitive points to memory
