[SOLVED] Ryzen 9 5900X temperature & noise issues ?
Oct 26, 2020
21
Just upgraded to a 5900x and my current cooler is a Hyper 212 Evo, cheap but works well, max temp with HWiNFO of 76'C while gaming.
The issue is my system fan is pumping 1900 rpm and annoying as <Mod Edit> as my pc is on my desk.
Is this something I can fix with software or do I need to invest in a better cpu cooler?
Thanks!
D
Deleted member 362816
Guest
That cooler will work in a pinch but is not really meant for a 5900x. dh-15 or a dark rock pro 4 would be more built for that CPU.
D
Guest
