Question Ryzen 9 5900x too Hot!!
Apr 17, 2022
16
Hello, so i think im having a problem with my cpu right now, it´s my first time using AMD, i already knew it was hot, but not that much, and i don´t think it´s normal. I have the Ryzen 9 5900x and in idle its staying at 80ºC, any task that i use it just jump to 91ºC, CPU is always spiking to max clock speed 4.4ghz, sometimes goes to 4.7ghz, so i don´t think it´s normal 80ºC in idle. Im using the watercooler in front of my case to get the best fresh air possible, and i already checked all fans to see if the air is flowing right. 3 fans at the front + 2 from the watercooler + 2 on top to push the air to the outside and 1 in the back to help pushing the air outside. Power plan is set to balanced and i changed nothing there, the temperatures just drops to 66ºC if i put the energy settings to power saving mode. But for someone who play heavy games and stream this is not the power plan i want.
My setup:
Ryzen 9 5900x
MSI CORE LIQUID 240R V2
MSI B550 GAMING PLUS
CORSAIR VENGEANCE 3600MHZ 32GB
SSD CORSAIR MP 600 CORE 1TB
WINDOWS 10 PRO
I think you are right, but i can´t stay 15~30 days waiting for warranty without my pc, so i just bought Corsair icue h150i cappelix, gonna send the core liquid for replacemant after the other reach my home, and then ill sell it. thank you anyway.
