Question Ryzen 9900X+X870E: Max no. displays from iGPU?
Does anyone know:
  1. Max no. displays (4K @ 60Hz) supported from integrated graphics on Ryzen 9900X? (I already tried to search, some sources say THREE, other say FOUR, anyone know which is correct?)
  2. Max no. displays (4K @ 60Hz) which can be connected via USB 4 + HDMI ports on X870E Mobo?
I am planning new build using Ryzen 9900X and an X870E Mobo. Will not be used for gaming, for productivity only. I won’t install a discrete graphics card, will rely only on integrated graphics.
I wonder how many displays (4K @ 60Hz) I could drive from the CPU and Mobo? All these Mobos have 1 * HDMI socket and 2 * USB 4 (supporting DP over USB).
In principle, each USB 4 port could output to two 4K @ 60Hz (using an MST USB-C to dual DP adaptor). So I wonder whether it might be possible to drive FOUR, or even FIVE 4K @ 60Hz displays?
Not yet decided which Mobo to buy, will likely choose from one of the below six options:
  1. ASRock X870E Nova WiFi ATX
  2. ASRock X870E Taichi Lite
  3. ASUS ProArt X870E-Creator
  4. GIGABYTE X870E AORUS PRO
  5. GIGABYTE X870E AORUS MASTER
  6. MSI MPG X870E CARBON WIFI
I wonder if anyone has tested max no. of 4K displays which could be connected via any of these Mobos from iGPU?
