[SOLVED] Ryzen High Performance Power Plan
reio
41
Hello,
I can't find the Ryzen high performance power plan.
I've updated to the latest chipset driver.
That only brought me the Ryzen balanced performance plan, but i want the high performance one.
CPU: Ryzen 3 3200g
MOBO: ASRock x570 Phantom Gaming 4
Your CPU is Zen+, so you don't need the AMD Ryzen power plans anymore, as all the optimizations from those power plans are now built into Windows.
Zen 2 is the only AMD architecture that still relies on AMD-specific power plans, due to their design.
So all Zen, Zen+ and Zen 3 chips do not require AMD power plans anymore.
So you're saying my cpu is too old for the power plan? aww, big sad
LOL...no.
What's more likely is BIOS updates (you ARE up to date, right?) and/or Windows updates have made it unnecessary.
If you really want to, go looking for 1Usmus' power plans. I've got them and they do nothing for my 5800X. So I just use Windows' plans.
You might also enable the Windows Ultimate power plan. Furnished by Microsoft but usually hidden.
