Hello. I know that the problem is rolled, I have read a lot, but I do not know what to do in this situation.
I have a Ryzen 5600x on the AM4 Gigabyte B550M AORUS Elite motherboard.
Everything is in a relatively small case - Corsair Carbide 175R Glass RGB Case.
The processor is cooled by the Arctic Liquid Freezer II 240 (one of the better rated).
The problem is that the processor without stress works at a temperature of 45-55 degrees (this is acceptable), but in games it immediately jumps to 80-85 degrees and stays in this range (I have never seen it reach 90, the max I have observed is 87).
After turning off the game, it drops down rapidly, and in a few seconds it can drop by 20 degrees.
Theoretically, AMD says that high temperatures for this processor are ok and with boost, it will always work in the upper limits.
However, I am worried that they did something wrong in the store (paste, fastening, etc.).
The case has 3 fans throw away air (one on the back and 2 on the top), the processor cooling is on the front, so it takes cool air from the outside.
The computer is under the desk, so warm air is actually collecting in the upper part, but the RTX 3070 card works at a load of 60-70 degrees max, so the case is cooled well.
Do you think these CPU temperatures (80-85 during stress) are ok, or is it better to take it back to the store to have it checked? The computer is 2 weeks old, so they shouldn't be doing the problem.
It works great, but this processor heats up incredibly in games, and the fans on the proscesor's cooling run at max.
I will be grateful for your opinions.
