S5000XVN Intel Power Signal Connector
kingzx87
25
Hi i have a Intel S5000XVN, and have ATX Power Supply. The motherboard need a power signal connector my ATX power supply dont have this conector is a conector of 5 pins
Power Supply Signal Connector Pin-out (J9D1)
Pin Signal Color
1 SMB_CLK_ESB_FP_PWR_R Orange
2 SMB_DAT_ESB_FP_PWR_R Black
3 SMB_ALRT_3_ESB_R Red
4 3.3 V SENSE- Yellow
5 3.3 V SENSE+ Green
and need a temp sensor :cry: :cry: :cry: , is posible run this motherboard without these connections Power signal and temp sensor? is posible create this conector?
Power signal connector:
step8.gif&w=712&h=382&ei=f0orT9L6LMi42QWB8KDwDg&zoom=1
:sweat: Help Please!!
Yes, on both the types they don't show the processors you are using... why do you think I've been saying they are not compatible........
No Problem, you're welcome and am really sorry for you, that you ended up buying that stuff but you might still be able to make good use of it elsewhere....
Always plan your buy and be very careful about picking stuff when it comes to servers.... sometimes you can get the best of stuff and not be able to make it work together and sometimes you can just land up with a rig that blows the lights out of everything else you might ever come across.
So it's better to be safe than sorry....
Come back and ask when you plan to make another rig.... we're here to help.
