I had asked my friend to get me a D975XBX2 from the US. He ended up getting me the S975XBX2 (which is the server variant). Rest of the configuration is in my signature below.
Here is the problem I am having. The Corsair XMS2 (TWIN2X2048-6400C4) memory I have is rated to run at 4-4-4-12 at 800MHz at 2.1v. On this board, I am only able to run it at 5-5-5-18 at 800MHz. Everest shows that my memory is running at 1.8v (DDR default). In the BIOS, there doesn’t seem to be any option to set the voltages.
The reason I wanted the D975XBX2 was mainly for its voltage adjustability, but this is the board I ended up with.
Is there some way for me to set the voltage to 2.1v? The D975XBX2 and the S975XBX2 share the same BIOS and drivers etc. Is there any jumper etc. setting that would allow this.
Thanks in advance.
Thanks in advance.
