Hello,
I just started this build yesterday, and this is my first build so I'm not entirely sure where the problem lies. The parts in use and in question are listed below:
-Asus Sabertooth x79 mobo
-Cooler Master Hyper 212 Evo
Everything else seems to be working properly on initial boot except for this heat sink. I have this fan plugged into the correct 4-pin CPU_FAN located on the top of the mobo. When I get to the POST it tells me there is a "CPU Fan Error" and to "Press F1 to Run Setup" which leads me to the BIOS.
In the advance settings it displays N/A along side the CPU Fan, which leads me to think its not picking it up or detecting it. I have also tried changing the upper limit of the fan to a lower temperature to see if a higher temperature would trigger the fan, but no success yet. I've included pictures of the mobo connection, POST, and BIOS screens. Any advice to get the fan up and running will be greatly appreciated.
