hello, i have lg 24gn65r-b gaming monitor i bought it cuz i was told its the same panal as the 24gn650-b with few changes like the osd
after i got it i went to service menu to see the panel name and compare it with the 24gn650-b and i found it same but the issue is i found 2 videos on youtube with the same model 24gn65r-b as mine but the panel name is different mine is the the one in with the green lines in the photos so is this normal cuz the (LM238wf6-ssa2) brightness is higher cuz the led current setting is default to 65 rather than the 41 for the (MV238fhm-ng1) one " this option cant be changed in the service menu if i set it to aythin rather than the defaults it reverts on its own " so if any one knows if this noraml or not pls tell me i did a "nvram init " and found that the panel was set to (mv238fhm-ng1) so ig i didnt change it but mistake or something in the first place
https://ibb.co/0hSCk2M
