Same problem with me after restarting my K55VJ SX 120 D ASUS laptop the screen is not getting ON. Power indicator and battery
Same problem with me after restarting my K55VJ SX 120 D ASUS laptop the screen is not getting ON. Power indicator and battery Led us glowing. Ram indicator is not blinking after 1 second. Somebody please give solution
Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
Try this...
