[SOLVED] Same RAM brand and model, but different speeds. Will it work?
LackuJacku
15
Hello
I am wanting to get another set of 2x8gb ram, but a lot of them are out of stock. Right now I have 2x8gb ram already in my PC, but it base clock is at 3000mhz and I overclocked it to 3200mhz.
I want the exact same speed and model of course, but all of them are out of stock. I am thinking of buying the same ram brand and model, but instead it has a base clock of 3200mhz. Will I have any problems with my computer if I were to install 2 sets of ram with a minimal speed difference?
Ram I have: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz
Ram I want: CORSAIR - Vengeance LPX 16GB (2PK x 8GB) 3200mhz DDR4
Motherboard I own: gigabyte z390 aorus pro wifi
They'll probably work together. Personally, I haven't tried it with DDR4, but my experiences with DDR2/3 suggest that as long as you clock to your slowest / least capable module, odds are good you'll be fine.
Asked here multiple times per day.
The answer remains the same: It might work, it might fail.
Just today:
