G gschilling Reputable Sep 14, 2014 8 0 4,510 Oct 21, 2014 #1 What kind of performance increase would I see with the more expensive 850 Pro as my OS drive on a video editing machine vs. the older 840 Pro? Looking at upgrading my four year old AMD Phenom II X6 based workstation.
Solution spooky2th Oct 21, 2014 Both are excellent SSDs. There's no difference that you will ever notice between the two. According to SSD Boss,is unaware of any differences/advantages but the life expectancy of the 850Pro is about 35% higher than the 840Pro.
spooky2th Splendid May 18, 2010 4,852 0 26,960 Oct 21, 2014 Solution #2 Both are excellent SSDs. There's no difference that you will ever notice between the two. According to SSD Boss,is unaware of any differences/advantages but the life expectancy of the 850Pro is about 35% higher than the 840Pro. Upvote 0 Downvote Solution
