Have a samsung 52" with 4 25v 1000uf 85c capacitors in the power supply board. 2 were blown. replaced those 2 with nichicon 35v 1000uf 105c capacitors. I understand you can go up in voltage and heat resistance as long as the uf is the same, but i have replaced those capacitors twice now with the same results, they blew within 3 days. Should I replace all 4? I saw 50v 1000uf 105c capacitors online, should I go with those instead?
