Samsung External Ultra Thin DVD Writer SE-208 Don't Work
Compuuser
My External Ultra Thin DVD Writer SE-208 Don't work. I've got this message:
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Date: 2017-05-21 21:39:42
Event ID: 441
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: DESKTOP-0ACDI9F
Description:
Device USBSTOR\CdRom&Ven_TSSTcorp&Prod_CDDVDW_SE-208GB&Rev_TS00\S16B6YMG400GHQ_&0 could not be migrated.
Last Device Instance Id: SCSI\CDROM&VEN_HP_HLDS&PROD_DVDRW__GUD1N\4&1FD8D0C4&0&020000
Class Guid: {4d36e965-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FE00FFFFF130
Present: false
Status: 0xC0000719
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" ></Provider>
<EventID>441</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2017-05-21T19:39:42.649672600Z" ></TimeCreated>
<EventRecordID>606</EventRecordID>
<Correlation ></Correlation>
<Execution ProcessID="4" ThreadID="3048" ></Execution>
<Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
<Computer>DESKTOP-0ACDI9F</Computer>
<Security UserID="S-1-5-18" ></Security>
</System>
<EventData>
<Data Name="DeviceInstanceId">USBSTOR\CdRom&Ven_TSSTcorp&Prod_CDDVDW_SE-208GB&Rev_TS00\S16B6YMG400GHQ_&0</Data>
<Data Name="LastDeviceInstanceId">SCSI\CDROM&VEN_HP_HLDS&PROD_DVDRW__GUD1N\4&1FD8D0C4&0&020000</Data>
<Data Name="ClassGuid">{4D36E965-E325-11CE-BFC1-08002BE10318}</Data>
<Data Name="LocationPath">
</Data>
<Data Name="MigrationRank">0xf000fe00fffff130</Data>
<Data Name="Present">false</Data>
<Data Name="Status">0xc0000719</Data>
</EventData>
</Event>
and I don't know what to do.
I'm here again. I discovered that if I click on the address on the line <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> I get this message:
Theresource you are looking for has been removed, had its name changed, or is temporarily unavailable
I think that this is important. But I don't really know.
Yes. I have tried several USB 3.0 ports and one USB 2.0 port. I tried the USB 2.0 port because the computer complained that I used a USB 3.0 port. This External DVD has worked on this computer before with the same operating system, Win 10 pro, connected to a USB 3.0 port.
