Samsung Hard Disk Firmware update...except my hard drive isn't from Samsung
ForTheMoney
7
I built a new PC today, and plugged in a HDD with Windows 10 already installed on it. It boots past BIOS, but then prompts me to update my hard drive disk with a message saying "Samsung P120S SP2X04C Series Hard Disk Drive Firmware update". Pressing yes is met with "disk not detected" (which shouldn't be, I don't have a Samsung hard drive), and pressing no prompts me to restart the computer. I plugged in a clean hard drive with only some backup files on it, and was met with the same problem.
Both the non-Samsung drives are detected on the BIOS screen, and when I plugged it into a toaster dock, the user and system files are intact. I am able to boot onto a Windows 10 media creation flash drive, but I'd like to be able to boot from the hard drive with Windows already installed.
It's possible the issue has to do with updating the drive through USB.
Probably what you'd need to do is have the drive installed as a secondary drive, then run the firmware update.
THIS may not be the latest, but I can't be bothered to hunt down the exact link especially if the update works for you easily once it's not USB:
https://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-58376-1&cc=se&dlc=sv&lc=en&os=2093&product=395634&sw_lang=
(and as said, you can't just plug in a copy of Windows that wasn't legally installed on that machine. The install process has to be initiated and finished on the existing machine)
The HDD with windows already installed is a Seagate, and the clean HDD is a WD. I will clean install on the newer one, see if that works. Thanks.
