How is that suspicious?
1TBW is well within a rounding error of 99-100%
in light of my 2tb samsung 970 evo plus with 30 drive writes, and my 1tb sn 850 at 9.5 drive writes with both still showing 100% life. thats why the 870 evo is suspicious to me
All of the drives in my primary system are SK Hynix (1x PCIe 2x SATA) and quite frankly I don't plan on going back to any other maker without a good reason. I have a Samsung 850 Pro which has been rock solid for years so I've got nothing against them, but their pricing leaves a lot to be desired. That's why I tried out the SK Hynix drives and couldn't be happier, and from reviews the new ones (Solidigm included) sound just as good.Honest question. Which brand is more reliable and better than Samsung then?
Every other brand I've seen is <Mod Edit>.
Yeah Samsung's new NVMe pro line is not as reliable as the EVO and QVO lines of SSDs, but every other brand is horrible worse by far
You need to manually update samsung magician from Website (current version is 7.2 I believe) some older versions fail to update anymore and say upto date (I assume secure server connection failure)While mine is only a 1TB, there is no new firmware as of yet.
Completely different drive and interface, but I have a 2tb Samsung Evo 870 with only 951gb of writes, yet it's showing 99% remaining life. That seems kind of suspicious to me considering I've only written about half of the capacity
I have a 980 PRO running firmware 5B2QGXA7, but there really is no new firmware available and I'm on latest Samsung Magician version 7.2.1You need to manually update samsung magician from Website (current version is 7.2 I believe) some older versions fail to update anymore and say upto date (I assume secure server connection failure)
Updated Magician to v7.2.1, still reporting No firmware update for the drive.Same situation with me. I was confused when I checked and my 1TB 980 Pro was already on an even newer firmware, version 5B2QGXA7. And while I don't recall when I last updated it's firmware, I know it was a while ago as my Samsung Magician app itself was several versions behind since I last used it.
I also got this drive in March of 2021 so it's not like it's new stock that was pre-flashed with that, I know I have had to update the firmware manually myself about 3-4 times since I got it.
Apparently, yes.I checked the date/time stamp of the payload file, 5B2QGXA7.enc. It's dated January 13, 2022. Does this mean that users have to approach Samsung individually to get their fix?
Still at 3B2QGXA7
Apparently, yes.
The newest version of Magician still shows mine as 'up to date'. Even though the 5B2QGXA7 is available at their site.
That 5B2QGXA7 IS the most recent version. There doesn't appear to be a newer one.I checked the date/time stamp of the payload file, 5B2QGXA7.enc. It's dated January 13, 2022. Does this mean that users have to approach Samsung individually to get their fix?
Right.The title of this thread made it seem like this was breaking news, not news from 1 year ago. :-?
"Samsung Issues Fix for Dying 980 Pro SSDs"
Possibly, the issue only affected drives with the previous version. And the issue was not known before now.
Starting in August? Still apparently months after the current firmware version.The issue has been widely reported in the user communities.
https://www.chiphell.com/thread-2435363-1-1.html
https://www.reddit.com/r/DataHoarder/comments/x8arle/psa_samsung_980_pro_users_in_china_are_observing/
https://web.archive.org/web/20221009111526/www.cnbeta.com/articles/tech/1313507.htm
Possibly they did not know, until it started appearing in the wild.If Samsung knew that these drives were going to be experiencing high failure rates, and if this one-year-old firmware update was intended to mitigate these failures, then why were they so quiet about the issue? Where were the warnings telling their customers that this was a critical, mandatory update?
