Samsung led smart tv dont have option to connect to wireless only wired connection
John_396
Commendable
Jun 20, 2016
Wireless connection on my samsung led smart tv only have the option for wired connection when i used to begiven both options
If you had the option before and it went away after a firmware update, contact Samsung support or go to their support page and check for a newer update you can try.
Have had this tv for 3 yrs now when had it set up at the begining it gave the option to wireless then the atomated updated the firmware and software now for the past 9 mos it doesn't give that option anymore
