[SOLVED] Samsung SA300 Problems (yes another one)
Vinnie2013
Im having problems with my Samsung Sa300 in combination with my Mac Book Pro. Everybody seems to fix the problem by downloading & installing new firmware; there is no firmware for mac.
please don't tell me to press the 'third button from the right', its not working.
please help
Why do you want analog? Actually it doesn't matter cause you don't have a choice. If you hook your MBP to an external monitor, it's going to output whatever the MBP outputs as, in this case it sounds like digital.
It says "Check Signal Cable Digital". I want to switch it to Analog. I can see al the options when I press the menu button but I'm not able to select the option. I can only switch it to PC or AV.
