Samsung Series 5 battery won't charge and adapter is required at all time
Itsmarc
Hi Guys,
My Samsung Series 5 NP530U3C-A01 battery won't charge and the laptop shuts down when I disconnect the ac adapter. I've tried to charge it with a new adapter and i've changed the battery with a new one. Both didn't solve the problem.
I've tried to reset the EC of the battery, did a BIOS update, tried a different OS and checked the internal DC-Cable. Nothing worked.
Is there anyone who is experiencing the same problems or/and has a proper solution?
With kind regards,
Marc
Well, I had the same thought but then I realised; what if both batteries are dead? And how can I be sure that the mainboard is broken, or the batteries? Does anybody have experiences with by measuring a mainboard/battery? The battery has a 9-pin connection to the motherboard, 3 red, 3 brown and 3 black wires.
I have just had the same - looks like the battery just gives up the ghost (even though it still has 61% charge) on my NP530U3B-A01UK
It seem sudden batery failure may be a feature of the NP530 http://ultrabooknews.com/2014/02/10/samsung-series-5-ultrabook-battery-replacement/
Bad new - the site he mentions above is sold out. The next cheapest replacement I can find is £115! Maybe time for a new laptop rather than spending 25% of the cost of the laptop on a new battery :)
Anyone else seeing this?
Cheers
Stef
I am also facing the similar problem. When I remove the adapter, computer goes power off. When I connect the adaptor, battery icon shows 100% charging, but as I remove the adapter, computer goes power off. Any solution please?
Hi, did anyone find a solution for this? My Series 5 started shutting down with the AC adapter about 3 weeks ago. Won't work unless it's plugged in. I ran a battery assessment tool and it says the battery is good and should take a charge.
Am about to order a new power cord, but won't if that's not the the actual problem.
Thanks,
Lisa
I also have the same problem and haven't found a solution yet either. This is a crap battery that dies after a couple years of life. It is ghosting in the computer. Make sure you properly shut the computer down and don't accidentally unplug it. I can't even find a cheap China replacement on eBay. If anybody finds a replacement, please let us know. Thanks
Same problem here. Battery led keeps blinking and battery is not charging.
And I can't find a place to get a battery from! any one knows about a reliable source of spare parts?
Regards
Juan
Same problem here. Mine is a NP530U3B-A02. Started day before yesterday. Laptop shuts down when power cable isn't attached. Battery meter says 93% charged but not charging. Power light is blinking green/amber. Clock resets itself every time I unplug the laptop. I ran a full Norton scan and checked my updated programs list just in case something stupid showed up on the laptop, but found nothing wrong. I travel a lot, so this is a problem for me.
A quick search for replacement batteries suggests getting one is no easy feat.
I'd love to hear what solutions people find.
We need to address this to the Samsung tech support. I have the same problem and I brought a new original battery for 200 euro and It did not work. I feel that it not OK that this ultrabook don’t last longer. Everything works fine with power cord by the way. (sorry for bad English)
I have look up in diagnostic tool in linux that OS cant find and battery so it must be a hardware problem.
Update, new battery is now chargin, it was very easy to change , there is a good Youtube video that helps you a lot in that process.
The problem is solved. I bought a new original battery in a webbstore in Sweden for around 120 Euro, the delivery was only 3 day with DHL. https://www.batteries-online.se/batterier-till-datorer/samsung/laptop-batteri-aa-pbyn4ab-for-bl-a-samsung-np530u3b-6250mah-original-samsung.html
Itś easy to put in the battery just follow the instructions on this youtube video: https://www.youtube.com/watch?v=k7QncSWHpMs
Big thanks to Steve ”Chippy” Paine for the video.
Just make sure that you put in the pins for the battery correct. (I did one wrong the first time)
